XCeed Pro Ceed GT Lenkrad Umbau
- acbw132zug
- 10. Apr 2024
- 14
Hello bro,
Does English work for you? I’m a ceed SW 1.5 tgdi owner from Taiwan.
Currently I did the same thing like you but a little bit different. I used the kia K5 gtLine steering wheel with shift paddle but using the original function buttons and harness. I cannot use the one come with K5 steering wheel together since the K5 function button doesn’t have the same layout like ceed.
What I already did was cut off the paddles wires and already connect them the each side of clock spring.
I tried to connect the wires to the shifter but I think I found the wrong wires and shift got no feature now. My shift paddles got 2 wires each, I think the yellow one should be connected to common line, is it GND? I’m not familiar with the canbus or none canbus system.
It will be very helpful if you can give me some guide to made it working. Thanks.
- acbw132zug
- 10. Apr 2024
- 14
BTW, I believe that it’s possible to get the right wire from the shifter as well.
Can you share the shifter connector definition with me? Many thanks.
- acbw132zug
- 10. Apr 2024
- 14
Hello, I'm using google translator, maybe I miss something? I just tested and confirm that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
- acbw132zug
- 10. Apr 2024
- 14
Hi Bro, I think I understand now. Now the only thing is if mine EM11 pin definition(1.5 tgdi) same as yours(1.6 tgdi). Basically I think it would be the the same.acbw132train hat geschrieben:Fr 12. Apr 2024, 16:11Hello, I’m using google translator, maybe I miss something? I just tested and confirmed that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
Can you mark out where is 34 and 12 hole of EM11 for me? I will check mine. Is the wire color same as the one mentioned in the diagram(Green and Pink)?
Many thanks bro.
See at the Picture. You need two new cables to the steering wheel column.
- acbw132zug
- 10. Apr 2024
- 14
Thanks bro! I will try it out. I already added new cable but not yet connect them. Will reply the result once I completeandreas87 hat geschrieben:Fr 12. Apr 2024, 21:03See at the Picture. You need two new cables to the steering wheel column.
- acbw132zug
- 10. Apr 2024
- 14
Hello bro, it works! Thank you very much!acbw132zug hat geschrieben:Sa 13. Apr 2024, 02:31Thanks bro! I will try it out. I already added new cable but not yet connect them. Will reply the result once I completeandreas87 hat geschrieben:Fr 12. Apr 2024, 21:03See at the Picture. You need two new cables to the steering wheel column.
EM11.JPG![]()
- BSB-Coolio
- Ceed (CD) Platinum Edition
- 09. Jun 2024
ich habe mir ein GT-Line Lenkrad in meinen Ceed Platinum BJ 2018 eingebaut.
Das ich ohne das vibrieren leben muss ist in Ordnung, aber seit dem Umbau funktioniert mein LKAS nicht mehr.
Die Anzeige im Display wird bei erkennen der Strassenmarkierung zwar grün, wenn ich aber ohne blinken den Mittelstreifen überfahre,
kommt kein Lenkeingriff. Was kann das sein?
Sonst funktionieren alle Tasten korrekt
servus,
besitzt das lenkrad schaltpanels?, wenn nein wurden die kabel für den haptikmotor ausgepinnt? Thema Kurzschlussgefahr!
- acbw132zug
- 10. Apr 2024
- 14
Hi bro,
Currently I'm working on illuminated door sills which got led. But after testing the fuse on ICU I can't find one suitable. And since I don't have circuit diagram. Can you help to point out on which connector and which wire can I get the 12v triggered only when the door is open? Thanks in advance.
- acbw132zug
- 10. Apr 2024
- 14
BTW, it would be very helpful if you can help to point out connector location as well, thank you very muchacbw132zug hat geschrieben:Di 24. Dez 2024, 10:22Hi bro,
- acbw132zug
- 10. Apr 2024
- 14
Hi bro, can you show the circuit for the lane assistance button on the left hand panel as well? Just successfully disable ISG on start automatically with an delay relay module. And want to see if same idea can work on lane assistance button, thx.andreas87 hat geschrieben:Mi 1. Mär 2023, 22:55Hab mal paar Gedanken gehabt zu der Start/Stopp und dem Spurhalteassistenten.Pinto hat geschrieben:Mo 27. Feb 2023, 17:40Respekt für den Umbau bei einem nicht VW-Produkt, da traut sich nicht jeder drüber...![]()
Bei Kia geht leider nichts mit programmieren.. Wollte die Start/Stop und auch den standartmäßig eingeschalteten Spurhalteassistenten deaktivieren, trotz Connections keine Chance...
Hier siehst du an der Start/Stopp den Schalter und die Steckverbindung unter der Konsole.
Man könnte also zum Beispiel ein Arduino Nano zum schalten des Signals verwenden. Quasi immer wenn Zündung angeht und die LED am Schalter aus ist dann einen Impuls geben um die Masse zu schalten dann würde der Arduino immer wenn Motor angeht den Schalter betätigen und die Start Stopp wäre aus.
Man kann die Stecker bestellen und einen Y Adapter dazwischen machen. Ebenso kann man dann den Arduino sagen wenn ich trotzdem den Schalter betätige dass die Start Stopp wieder aktiviert wird.
Das selbe Prinzip würde auch für den Schalter des Spurhalteassistenten funktionieren.
Gibt es auch fertig hier zu kaufen:
https://www.carelectronic-webshop.de/ca ... odul_14_17
18470 -
- 5
31947 -
7797 -
Letzter Beitrag von Bernie 733
36986 -
38606 -
