XCeed Pro Ceed GT Lenkrad Umbau
- acbw132zug
- 10. Apr 2024
- 6
Hello bro,
Does English work for you? I’m a ceed SW 1.5 tgdi owner from Taiwan.
Currently I did the same thing like you but a little bit different. I used the kia K5 gtLine steering wheel with shift paddle but using the original function buttons and harness. I cannot use the one come with K5 steering wheel together since the K5 function button doesn’t have the same layout like ceed.
What I already did was cut off the paddles wires and already connect them the each side of clock spring.
I tried to connect the wires to the shifter but I think I found the wrong wires and shift got no feature now. My shift paddles got 2 wires each, I think the yellow one should be connected to common line, is it GND? I’m not familiar with the canbus or none canbus system.
It will be very helpful if you can give me some guide to made it working. Thanks.
- acbw132zug
- 10. Apr 2024
- 6
BTW, I believe that it’s possible to get the right wire from the shifter as well.
Can you share the shifter connector definition with me? Many thanks.
- acbw132zug
- 10. Apr 2024
- 6
Hello, I'm using google translator, maybe I miss something? I just tested and confirm that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
- acbw132zug
- 10. Apr 2024
- 6
Hi Bro, I think I understand now. Now the only thing is if mine EM11 pin definition(1.5 tgdi) same as yours(1.6 tgdi). Basically I think it would be the the same.acbw132train hat geschrieben:Fr 12. Apr 2024, 16:11<font style="vertical-align: inherit;"><font style="vertical-align: inherit;"></font></font>andreas87 hat geschrieben:Fr 12. Apr 2024, 15:14</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Have you read the entire thread? </font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Hello, I'm using google translator, maybe I miss something? I just tested and confirmed that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?</font></font>
Can you mark out where is 34 and 12 hole of EM11 for me? I will check mine. Is the wire color same as the one mentioned in the diagram(Green and Pink)?
Many thanks bro.
- acbw132zug
- 10. Apr 2024
- 6
Thanks bro! I will try it out. I already added new cable but not yet connect them. Will reply the result once I completeandreas87 hat geschrieben:Fr 12. Apr 2024, 21:03See at the Picture. You need two new cables to the steering wheel column.
- acbw132zug
- 10. Apr 2024
- 6
Hello bro, it works! Thank you very much!acbw132zug hat geschrieben:Sa 13. Apr 2024, 02:31Thanks bro! I will try it out. I already added new cable but not yet connect them. Will reply the result once I completeandreas87 hat geschrieben:Fr 12. Apr 2024, 21:03See at the Picture. You need two new cables to the steering wheel column.
177 -
- 5
3130 -
6797 -
1657 -
10289 -
